@ B E N
I'll bump up the load with failed MAF table. I have Autolite HT0's gapped to .032" I believe. I also have Accel coilpacks. I've been told the Accels can be problematic and I should get OEM coilpacks.
How do I get my lambda values below 1? I adjusted my base fuel table and blended it as you suggested earlier but my lambda hasn't changed. Does it only change during open loop? Should I adjust the "OL Fuel TPS Thresh"? It currently above 40% for any RPM under 5000.
I am writing the tune iteratively but I'm getting very frustrated. R26 means "revision 26" and I keep a detailed notepad log of all the changes of every revision. I also save every revision. I probably have 20 revisions with LTFT and DFCO turned off and I'm just trying to dial in the MAF transfer. I've done STFT, wideband and now LTFT+STFT adjustments and it doesn't seem to be getting any closer. I'm thinking either I have bad data, my workflow is off, or something is wrong in mt maths somewhere. I've likely done around 100 pulls and I'm STILL screwing with MAF transfer. I'm balancing learning this, with work and family so I expected it to take a bit, but I've been blown for 2 years and I've driven the car maybe 1000 miles total trying to datalog and tune it. I've also done a remote tune with Lasota, and visited 2 local tuners. No one got it running right, and no one had suggestions for how to fix it. It's running better than ever with the HPX5000 MAF and larger BOV, which were design changes I made myself At this point I feel it's my own inexperience holding it back from running great.
What are the dozen parameters you generally focus on? I'll narrow my focus to them.
@Robcat
I reviewed your R26 tune and adjusted my torque table. The IPC torque error was better in some spots. No worries on the long novels, I'll read and digest them. Plus I can be long worded too. I appreciate sharing the knowledge and info.
