Results 1 to 20 of 27
Thread: Another car guy tuning a RXP 300
    Apr 2022
    Brandon, MS
    31
    What's up guys, I have read all 3 pages of this BRP section and it appears most of us are car tuners trying to tune a Can-am or Sea-Doo. I recently bought a low hour 2018 Sea-Doo RXP 300 and was looking for tuning options and found out HP Tuners has the ability but there is not a lot of knowledge out there about the tuning process.
    I posted on Green Hulk and got bashed because I'm not using a MaptunerX. I'm not buying another $1000 tuning platform when I already have one that will work. I plan to start testing as soon as my adaptor cable comes in next week. I have seen some guys make huge gains on the Can-Ams with HP Tuners so it can be done. I will keep you all posted and any help would be great!
    Jan 2022
    Galloway NJ
    116
    My 21 GTX 300 is running better with HP Tuners than it did with Maptuner.. and I have the Riva map editor software and was modifying my own tunes.
    Apr 2022
    Brandon, MS
    31
    Quote Originally Posted by Tbranella View Post
    How did you get started on your HP Tunes? Trial and error? Or were you able to pull the maptuner tunes and do a tune compare to get started with the HP Tuning software?
    Jan 2022
    Galloway NJ
    116
    I started by comparing the maptuner tunes and copying the tables over.
    of course there's way more that needs to be changed that you cannot see in map editor.
    Apr 2022
    Brandon, MS
    31
    Cool, yea that was my plan as well. I know a guy with a "bolt on" maptuner tune and was going to pull it and do a comparison to get started.
    Did you install a wideband O2? I was just outside looking at mine and trying to figure out the best place to install a wideband.
    The Bluetooth feature of the HP tuners MPVI2 should make data logging easy.
    Jan 2022
    Galloway NJ
    116
    how are you going to "pull" his tune?
    yes, I have a wideband O2 installed.
    there's two round flats near the back of the exhaust manafold, use the one closest to the cylinder 1 exhaust port.
    Apr 2022
    Brandon, MS
    31
    I haven't got my adaptor cable yet but is reading the ECU not the same procedure as a car/truck? You download the current tune file? Then compare it to a stock file to see the changes.
    1. Download the tune file from my buddy's RXP 300.
    2. Download the stock tune file from my RXP 300.
    3. Compare the files as a starting point and modify from there.
    Thanks for the info on the wideband. I will look into that today.
    Jan 2022
    Galloway NJ
    116
    with HP Tuners, you can't "read" an ECU.. it reads your ECU and then downloads a stock tune file from their server based on the information from your ECU.
    so you'll only ever get a stock tune file from them... you cannot download a tune file from an ECM.
    Apr 2022
    Brandon, MS
    31
    Hmmm, ok I read that in an earlier forum but I thought HP Tuners had changed that since then. Surely HPT will change that in the future. Either way no big deal I will start from scratch. Thanks for the heads up.
    Apr 2022
    Brandon, MS
    31
    Well, I got my adaptor cable in a few days ago. Time for some testing and tuning. Any help or suggestions are welcome!
    Jan 2021
    cana
    5
    bonjour peut tu mettre la calibration d origine avec id merci
    Jan 2010
    33
    Quote Originally Posted by Allcagedup View Post
    how are things going? when you read your ski, did you have wifi/internet access when you read it?
    Apr 2022
    Brandon, MS
    31
    Quote Originally Posted by SloSVO View Post
    Things are going well but only a few days after getting my adaptor cable I had to go to Japan for business. I will not be back until this coming weekend.
    Yes, you have to have wifi while reading the tune from the machine. You will also need wifi and your MPVI2 hooked up while making modifications in the tune. The software has to ping the HPT server before opening the tune file.
    Jan 2010
    33
    Well that sucks balls
    May 2020
    I just got my 22 RXPX and its in storage for the winter, my question is what does the ECU have for AFR reading? No way of utilizing this?
    Tuner RUTHLESS's Avatar
    Sep 2022
    WorldWide
    144
    good afternoon everyone, who ever need help tuning a seadoo im more then happy to help 239-887-6848 text me
    Feb 2023
    France
    21
    Are you sure because i ve already a tune Stage 1 on my RXP X 2022 , and if HP Tuner send me a stock file : no interest.
    Jul 2017
    529
    Quote Originally Posted by Yann45 View Post
    Yes, this is correct.
    Obviously you can read out the .bin file, then convert it to .HPT if you like.
    Feb 2023
    France
    21
    Quote Originally Posted by MRRPMBRP View Post
    And is it possible with a MPVI3 HP Tuner interface for read out a .bin file? And for convert to HPT file which software can do it?
    Jul 2017
    529
    No, and contact HPT for file conversion
