I've been fighting my idle for months now. It seems to be software since I can see the car commanding what it is doing, it's just what it is commanding isn't what the tune should be asking for.
I've attached my tune and a log, but something has changed, and the ECU is now commanding a higher throttle without changing the tune. I can load old tunes that I have logs showing they used to command ~18% TPS at idle, and are now commanding ~21%. Both of those are high, and they should be commanding ~16%, but no matter what I change it won't go that low until adaptive idle kicks in.
So for now, any tips on why the exact same tune would be commanding 3% more throttle at idle?
The only thing that changed is I flashed the fuel pump control module with my tech II copy. But I don't know if that would have any effect
