im using a 2013 intake with eagle heads, 50.27 is the max airflow limit for that year intake. if i change the max airflow limit to a 2008 max airflow limit, would i be able to get more airflow with less opining of the throttle body without the pcm knowing? what im asking is, can i get the throttle to open more with lees input to feed the intake and give the cam more air from idle all the way throught the range? for whatever reasons i cant get a decent idle nor good power on take offs or wot. no power!
