LTG fuel injector help
Got my LTG to fire up and run on starting fluid. Doesnt seem to be firing the injectors, does anybody have a clue where to start looking?
are you getting any data from the injectors ? pulse width , rail pressure ok ,wiring all good check fuses FIRST and then harness .
Gettin no injector data on VCM Scanner. Rail pressure good, fuses good. Need to pull off intake to get to wiring and do a pin out. Would it not throw a code if something was wired wrong?
