I recently got some help to get a decent working tune as far as idling with fuel trims dialed in goes. But something just doesn't seem right to me. I attached a couple of logs of startup and idle and another with a short drive. I get a pop every now and then and quite a few parameters seem really off to me. Like Trans-Engine-Torque Requested at 1141 ft/lbs, and I seem to have an unbalanced condition between bank 1 and bank 2 where one is richer and one leaner, and though it says via the scanner that I am not in limp mode, I'm pretty sure I am, as I am stuck in 3rd gear anytime I go into drive e right away. I'm showing a Permanent U1424, P1DD2 codes as well as a few others. My fuel trims show pulling 25% sometimes but at the same time, my wideband is showing a lean condition with an AFR between 18-20. If anyone at all could watch through my log here and help me out here with some input based on what you see here, then any help would be greatly appreciated! Truck description in signature as well. Thanks!
