OK, Here's the rundown.
06 Trailblazer SS, e40 ECM running closed loop speed density.
Original LS2 Block, Stroked to 403
AFR 220 Heads
NW 103 TB
LSXRT Manifold
AR Long tubes with cats into a single 4" exhaust
GP Tuning Custom cam 232/240 .627/.616, 114* LSA, 8* Overlap
3200-3400 Circle D Converter
Overall the truck starts idles and drives well with one really annoying quirk. It will die when holding very light throttle or upon returning to idle from a light throttle position. Attached is a log and the tune file. Most of it is just driving around, near the end I duplicated the problem a few times, in park and drive. Especially noticeable in park is the commanded throttle position dropping off while I hold the throttle pedal steady. Same thing in drive, once you let off the pedal it closes too far and can't recover quick enough. I'm hoping that's pointing toward the problem, I just don't know how to fix it.
