Results 1 to 3 of 3
Thread: MAF and MAP are still reading data but quit registering on graphing and tables?
    May 2022
    Brevard county FL
    2
    I made some changes on my tune and wrote it to the vcm. Connected the scanner and all is normal except my MAP and MAF are not registering on the graph or the tables? The data is on my pid list reading properly. Any help would be appreciated, I'm sure it's something I did, Im just not sure what.
    13,565
    Connect to the vehicle again but don't start scanning, click vehicle at the top and click re-poll for supported parameters. See that helps the issue.
    May 2022
    Brevard county FL
    2
    Thanks for the response. The repoll was grey'd out and not a viable option sadly. I found another post with a similar problem. Fixed by loading an older data log with everything graphing like it should and saved the layout. Closed it and loaded the layout, yahtzee, back in business.
