Results 1 to 8 of 8
Thread: MAF Fail Frequency
    Tuner in Training Dynamic's Avatar
    Mar 2015
    Washington
    17
    MAF Fail Frequency
    I sincerely apologize if this has been covered. I couldn't find it in my search if it was.
    Where can I find the MAF fail frequency? I'm working on a 2003 Chev S10 with 4.3/automatic. I read that is should be under Engine Diag, but there is only a list of DTC's under that tab.
    Thanks!
    2004 Dodge Durango, 5.7L Hemi, 10:1 compression
    -SRT8 cam, advanced 6 degrees, 6.1L valve springs
    -Manley pushrods
    -Scat rods, Speed Pro pistons
    2004 Dodge Durango, 392 Stroker, 11:1 compression
    -Custom cam grind, 221/230, .575"/.585", 115 LSA, 3 degrees advanced)
    -Scat forged 4.05" crank, Scat Ultra Q-Lite H-beams, Mahle forged pistons
    -Stock heads with 6.1L valves (2.08", 1.60"), bowl work to match new seat profiles
    -PSI LS1511 valve springs
    Advanced Tuner dhoagland's Avatar
    Jun 2015
    Aubrey TX
    890
    Post the Tune File
    Mar 2015
    Washington
    17
    Here is the current tune file.
    S10 Tune File - 6.8.2022.hpt
    -Manley pushrods
    Jan 2019
    Australia
    81
    Its under engine diagnostics - Airflow Tab
    Mar 2015
    Washington
    17
    That's just it... There is no airflow tab under Engine Diag. There is only a list of DTC's.
    -Manley pushrods
    Jun 2015
    Aubrey TX
    890
    Quote Originally Posted by Dynamic View Post
    Your in Basic view
    Turn on Advanced (Pictured)
    Here is a shot of your file I opened
    Mar 2015
    Washington
    17
    Well look at that! Man, I sure appreciate the help. I feel like an idiot sometimes messing with this stuff. Thank you.
    If you need any setup help with that 48RE, let me know! That's what I do...over, and over, and OVER again! LOL
    https://dynamictransparts.com/
    -Manley pushrods
    Jun 2015
    Aubrey TX
    890
    https://dynamictransparts.com/[/QUOTE]
    Good to know...
    [Knock on Wood] Its hanging pretty tough right now....
