2003 GMC 2500 light duty pickup. Freshly rebuilt 6.3 LS stroker, 1000hp-4L80E build and 4x4 solid axle conversion. After thinking I had some trans line pressure issues in the 4L80E, the trans shop that did the rebuild verified all was well with the transmission itself but we identified that the incorrect stall torque converter may have been shipped, installed, and now we're out of time in the short term to swap the torque converter out for a lower stall. I'll address that in a few months.
In the meantime, is there anything I can focus on within the tune that may help "fudge" this converter to feel more like a 1200-1400 stall?
Reason being, is in Reverse or in D (1st gear manual as well) there is more than sufficient transmission line pressure to hold the clutches (120psi idle 190+ when revved in 1st gear, 170psi idle and almost 300psi in Reverse according to manual gauge tests), but the truck is rolling down an incline opposite of the gear direction. For example, in Reverse, nose pointed downhill, when I let off the brakes the truck will roll forward down hill as if I'm in neutral until I rev the engine up to ~2000ish, and then it'll abruptly move in Reverse, sometimes chirping the tires. Same with moving in forward 1st gear. If I'm nose pointed uphill and want to drive forward uphill, the truck will roll backwards a bit first until I rev up.
I just hate having to 2-foot this truck on a hill, which should be rock solidly stable and not rolling away from me, especially when trying to back up a trailer or crawl over a boulder/obstacle. I'm trying to confirm with the trans parts supplier which converter they sent me, but I have a feeling it's too high for this truck.
Any advice? Uploading my most recent work in progress tune - note I am only about 10% done with VE and spark tuning.
