I'm trying to read my 2021 Renegade 1000 and keep getting the message,IMG_3637.jpg Detect Protocol Failed. I just upgraded to the MPVI 2+ and I'm using the latest Beta version. Any help would be awesome.
According to the website article:
If you have an MPVI2, connect to the internet and try a resync. If that doesn't work, then I would contact support to ensure the ecm is supported.
https://support.hptuners.com/hc/en-u...be%20resynced.
Hi, I'm Having same issue with 2015 seadoo. resync'd mvpi2. Started support case. Did you figure anything out? Noticed interface obd plug hot to the touch? anybody else noticed this?
Yes connected to Wi-Fi. Tried changing firewall settings, tried new version of beta. Switches from no battery power to failed protocol message. Started a help case, they asked for files. I sent today but probably will be two days before get response.
having the same issue with my 17 turbo r x3
2000 2500 CCSB 4x4 OBS 6.0LQ4 swap, Magnacharger
2015 SS sedan ls3 w/ LSA
1989 rx7 ls1 t56
1970 chevelle 540bbc w/ls fuel injection 0411
So figured out my hp tuners BRP cable was bad and reason for getting hot. took temp gauge to it and it was 171 degrees. Hp sent me new cable and now it connects to boat, but since its a 2015 ski and me17.8.5 ecu they don't have in database. Sending ecu to hp tuners to add to there database so I can tune it.
