Results 1 to 9 of 9
Thread: Hellcat Commanded EQ Ratio goes lean at WOT
    Oct 2013
    211
    Trying to clean up a tune for a friend on his trackhawk, the vehicle has a cam and is stock otherwise. Doing a 5th gear pull on the dyno around 5200 rpm the commanded eq ratio starts going lean, I also noticed throttle tq source says transmission. any pointers?Trackhawk engine and trans tune 3.hptTUNE 3.hpl
    Hello, I am no Pro at tuning by any mean.
    but could you just not add a bit more fuel from 5.2k rpm and up?
    Oct 2013
    211
    Its a closed loop system, I can add as much as I want but its commanding a higher a/f so the actual a/f will follow it and pull the fuel back out.
    Ah I see. Sorry I do not have more information.
    Advanced Tuner coanan's Avatar
    Mar 2009
    S. Florida
    582
    NN is off.
    If your not in PE, then increase VE there. if you want PE earlier, then decrease pedal voltage to go in earlier.
    2018 Trackhawk PCM/TCM tune by Dusterhoff.
    Flex Fuel, MMX faux 95mm TB, GripTec 2.85, 10% ATI lower, FIC1200, ARH 1 7/8 w/cats, 180 T-stat
    13 Chrysler 300S, RAM BGE 412 stroker, cam motion 232/246 619/619 118 +4, ATI 18% OD pulley
    Whipple Gen5 3.0, 2.50 upper pulley, Smooth Boost controller, FIC 1200 inj. Nick W 108mm TB, FORE dual return fuel system, E85, FTI 2800 stall(SRT83380), SHR WAR Viking trans and valve body, Getrag 3.73, 1 7/8 kooks w/hi-flow cats, 3" Magnaflow Cat-back 943rwhp
    Nov 2009
    All Around
    3,149
    your transmission is the cause is torque source is changing
    return trans to stock and friction back to stock and retest
    Oct 2013
    211
    This worked thank you. I had to find a stock file but it carries commanded eq all the way through now.
    Mar 2018
    9
    Hey Zinc, im having the same issue can you let me know what you have done to solve it?
    Aug 2021
    Indianapolis Area
    179
    Hello,
    Transmission is under control of the situation due to several potential reasons (one or multiple):
    - Transmission temperature
    - Torque
    - Code (fault)
    In the measurement file, I can see potential improvement points:
    - torque converter
    - shift points
    - shift timing
    - torque limit
    - line pressure
    In case you would like to have tuning support, please, let me know (email: [email protected])
    Thanks.
    Dodge Boy
