Results 1 to 4 of 4
Thread: injector ID
    Jan 2021
    Miami
    351
    injector ID
    good day. im looking for the data for my injectors. im using a set of 2011-16 dodge injectors, the part number Mopar (5037479AD) with an orange ring on it. cant find the info on Injector ID website. im just using a 2013 dodge charge stock file for the info on the injectors. i feel the info might be off a little, i just cant get the fueling correct. what other injector site could i look at for the info? i see DW has some data but i dont see any for my part number. thanks in advance.
    By the prickle of my thumb something wicked this way comes!2008 Chrysler 300c! 2013 heads/220/230 comp cam/LTheaders/FTI 2600 stall converter.
    that part matches to a 5.7l 2018-19 challanger
    googled
    shows this stock tune & it should have the data
    https://forum.hptuners.com/showthrea...l=1#post664741
    Quote Originally Posted by Turbo2gnx View Post
    Dec 2021
    Spain
    51
    hi, trying to determine the flow for injectors 5037479AD (2019 model) to test them in bench: does anybody around have it available?
    I saw this discussion, and I found 5037479AC (2017 model) makes 26lb/hr @58psi does anybody know if this is the same flow rate for the 5037479AD?
    Advanced Tuner N2speed's Avatar
    Mar 2021
    Pompano Beach FL
    265
    Quote Originally Posted by Benjamin Lopez View Post
    they are the same
    www.n2speed.com
    http://www.amp4x4.com
    [email protected]
    Dodge And GM Tuning Suppport
    Diablosport CMR | HP Tuners
