Hopefully this is a softball issue for you guys. I'm having an issue where I have an Gen-3 setup that's cutting power way before the scheduled RPM limits. I'm scratching my head as to why. Fuel cutoff is set to 6800 but injectors cut at about 5500-ish. The vehicle is a manual trans application with cable throttle. Tune is set accordingly as far as I can tell.
I have a tune file and log of the activity attached.
In the log you can see right around 5500 RPM the TPS is still 100% and injectors are 12ms. Right after that you can see TPS is still 100% but injectors cut to 2ms. I can't say I've ever run into this.
Thanks guys!
run5_cut.hpl
TUNE_SD_KR_0013.hpt
