I have a few questions in regards to the HP90, I ran it a couple of months ago and blew a converter and then had the trans freshened up just incase and then got a brand new converter and I am having an issue where my Trans will shift fine sometimes and then at times it will bounce off the rev limiter and never shift into second gear until I let off. Then I had a instance that it shifted into second then third and then second again at WOT, I have attached the log for that run below.I have also attached the Tune file if anyone can take a look at them. I have done a comparison between my file and a demon file and I think I see where some issues maybe but I am not a tuner and nor do I want to call my tuner out, just looking for a little more info. Based on may comparison of the two files I am also wondering if for some reason the file became corrupt for one reason or another.
Reason: Add some text
That is a very common issue in case you have engine upgrades. TM is lost due to torque increase (or how fast it increases) or pressure issues or shift schedule issues.
