24x Swap Questions?
Have a few questions for my 24x swap.
As far as wiring I wired the coils using these diagrams for a 03 -06 chevy/silverado gmc/sierra.
Same as LS1 ignition coil wiring correct?
Wondering what tune is best to use? My current tune runs good and I have no problems with it. It is a express van tune tuned to my hardware. Do I start with another base tune like the 02 Camaro tune and copy and paste over my VE table and injector settings? Would that even work? Sorry for being a noob bros. Or would I need to tune it again? Keep my current tune and make some adjustments?
Also about the crank sensor. Can I use a 5.3/4.8/6.0 24x crank sensor on my vortec timing cover or do I need to buy the eficonnection one? Also for wiring Do I need to swap pins around for crank sensor? Right now I have it wired like the express van.
I know I have to switch the injector pins at the ecm for LS firing order.
Anything else I'm missing?
Keep L31 02 express van tune and simply change crank lo res to 0 and wire sensors and that's it?
https://youtu.be/aGK4kJ_13vY
Done a bunch of Mike's 24x kits. He put a lot of work into the front cover. I would gladly pay for his rather than take all the time to setting it up yourself.
Chumba was referring to the crank sensor and cam sensor. Mike has them both integrated into the front cover. https://www.eficonnection.com/home/c...ne/efi-24x-sbc
Not familiar with what you are using, where is the current crank sensor and reluctor wheel?
I've done a couple 24X conversions on LT1's and I've used the 2002 Camaro files to start.
