Cant seem to figure out why the maf wont log. Probably missing something, trying to tune the maf on my 04 rcsb lq4 with a btr stage 2 cam. any help is appreciated.
I see it reading in the channels, So you're having issues creating a graph or chart?
When you post a log we can only see your channels, so we can't see your graphs or charts layout unless you post them up.
Here is a screen shot of your log looking at it with my layout.
My guess is you are not using the right parameter (mine is LT + ST fuel trim error math).
Your column Axis is your MAF hz. You get the numbers (labels) from your tune. Your labels and mine must be a little different, in the channels its at 5225, its showing 5400 in my graph (could just be a few miliseconds delay from channels to chart?)
im having trouble with it populating on the graph. Ill put a screen shot in here
screen shot
Okay, that parameter is if you are using a wideband and logging AFR. Then it creates the error between that and commanded.
I pictured the "Math" for that
Since I don't see a wideband in your log you need to use fuel trim errors developed from your o2 sensors
I pictured where to find that in the parameter selector
Ok that?s great, I have an aem wide band but no module so no logging with that yet
Hey, look at the end of this log
Your o2 Voltage, Fuel Trims, and MAP all stop reporting, freeze, RPM MAF seem to still be working.
Wiring issue?
