Running into some issues here. Got maf tuned but have also had a delay in power until 3k rpm. ive raised my spark tables by just adding 1-3 degrees. im wondering if i need to just add more spark but my tip top low rpm spark is already around 40-50 which seems absurd. ive attached my fail and im just trying to figure out if i should add more until i start receiving spark knock or am i missing something. also if you do have the time to take a look im also in the middle of doing my first speed density since i'm now running a turbo and 2bar map. my main issue with that is i'm just confused on how my maf was as simple as taking the scanners readings and multiply by half until correct. iv'e learned thats the same for SD but it just seems like its not going in that direction. one run it will be up in the 10% lean then next 15% rich. i have debated on turning off power enrichment but then how do i get the top VE to be 11 afr if its trying to correct it to 12.4? Thank you to whoever can take the time and give some pointers!turbo step 1.2.hpt
