I got my car back up and running i switched over to a 0411 ecm after i fried the other one. here are the specs on the car
97 corvette
long tube headers
no cats
no rear 02
0411 pcm
The car starts and runs, but I am having the same issue as before it is very rich. the 02 sensors are saying it is lean my wide band is showing rich. at idle it will go to 8.5 on the afr gauge then start to stall out till i give it gas. All the plugs are black and sooty so it definitely is running rich. When i disable the ltft in the scanner it seems to run a little better. I checked for vacuum leaks with a smoke tester didn't find anything. i put the car into speed density and it idles a lot better, but i don't have my afr hooked up to hp tuners yet so i didn't want to leave it like that, I am at a loss here on where to go from here.
