Results 1 to 17 of 17
Thread: can some help and check this tune runs rough at idle
    Jun 2022
    14
    2005 chevy 6.0 swap with after market intake 42lb injectors 2005 CHEVY 1500 6.0 RAUL.hpt like if it has miss
    Advanced Tuner dhoagland's Avatar
    Jun 2015
    Aubrey TX
    890
    Post a log of the event happening
    2011 Camaro 2SS Convertible L99 Bone Stock for now
    2003 Dodge 2500 5.9 Cummins QC 4x4. Airaid, 2nd Gen Intake, Grid Heater Delete, D-Tech 62/65/12, Magnaflow. Bully Dog: Propane Injection, Triple Dog W/Outlook Crazy Larry. Edge EZ, BD Flow-Max, 48RE: Sonnax Sure Cure/Transgo combination, Derale turbulator, billet input, Triple Disc, Super servo, 4 ring Accumulator. :beer
    Jun 2022
    14
    silverado 6.0.hpl at idle in park
    silverado 6.0 1.hpl in drive
    Jun 2015
    Aubrey TX
    890
    Okay, I know I asked for a log...
    But Tune wise first thing that sticks out is injector data, It doesn't appear that has been changed in the Tune file posted.
    Post up the specific injectors that you have installed, and any data supplied with them.
    Jun 2015
    Aubrey TX
    890
    Stock Internals?
    Idle MAP kpa at 57? Vacuum leak?
    Jun 2022
    14
    Quote Originally Posted by dhoagland View Post
    Stock Internals?
    bought the engine from jegs atk engine performance am say stock internals and for thinjectors ther 42lb from hp performance injectors didnt came with data ive msj them if the have the datat ther response is ur tuner should do that but did sum reserch and they flow 43lb
    Jun 2022
    14
    i did a smoke vacuum test no leak am double check it agian
    Jun 2022
    14
    https://www.high-performance-engines...ine-p/hp93.htm
    here is the engine i bough if it helps any and sorry new to ls and tuning
    Jun 2022
    14
    Stock Internals?
    7,574
    If you want to be able to use garbage injectors that don't come with GM-format data, buy a Holley ECU that can be set up with little dropdown menus and forget all about this stock ECM stuff. If you want to stick with the stock ECM you're going to need injectors with accurate data.
    Jun 2015
    Aubrey TX
    890
    Okay
    "Custom grind Cam" in their technical data, so the idle kpa could be okay
    Do you have a part number for the injectors?
    In the link they say 36lb are what they have, you said 42...
    This is the most important thing to have correct, so many ECM calculations revolve around this. Stuff in the background that we never see.
    Jun 2015
    Aubrey TX
    890
    Beat me to it, LOL
    Jun 2022
    14
    Okay
    THER 42 INJECTORS ... AND THE I CHECKED THE INJECTORS AND THEY DONT HAVE PART NUMBER THIS WERE I BOUGHT THE INJECTORS https://highperformanceinjectors.com...37161423274181
    Nov 2017
    1,447
    Quote Originally Posted by supra1991 View Post
    'We provide injector deadtimes and flow ratings which makes calibrating your fuel maps easier. "
    Jun 2022
    14
    yeah i know when i bought my injectors for my supra came with data.. ive msj the suppler for the injectors he said that those injectors use stock data
    7,574
    That's not how this works. You can't redrill or modify injectors and have any of the critical data remain the same while only the flow rate changes. If they are unmodified GM 42lb injectors they should be able to tell you what application they were taken from, and what the GM part number is. Flow testing alone is not enough to get the full data for an injector.
    Jun 2022
    14
    [QUOTE=blindsquirrel;691698]That's not how this works. You can't redrill or modify injectors and have any of the critical data remain the same while only the flow rate changes. If they are unmodified GM 42lb injectors they should be able to tell you what application they were taken from, and what the GM part number is. Flow testing alone is not enough to get the full data for an injec
    ill try to adjust the lay around a bit with them to see if i can get her to idle more smoother i got her to idle better then the tuner were i took it to get it tune if ill just swap the injector for sume good brand with data sheet
