A4 B8 EFR Dyno Numbers
First time on dyno with the efr6258. Density Altitude was 3600 ft and temp was 101. Put 3 gallons of E in and filled up tank. Still mostly stock including block and internals, stock airbox, stock exhaust after the down pipe. Will add times when I get a chance to make some runs.
https://imgur.com/JLoGTy8
2011 A4 B8 Avant (S-line, Prestige)
BW EFR 6258
IE FDS IC
E-code tip/pipes/sound box delete
AFE drop in filter
Stock exhaust after DP
R8 coils
Ward Performance Tuning 93 oct HPT ECU tune
bb/bg HPT ZF8 Tcu tune
93 oct pump gas with 3 gals e mixed in
4160 LBS
19" s-line rims
TTRS 4 pot brembo 355x32mm rotor front/ s4 330 rear
