Effective Error Histogram
If you only have 1 error in a column, such as column 0.022, where the error is -.11.
The correction would be -.11/2=-.055, so you would add -.055(which is really subtracting) to the entire column.
If you have more than 1 error in a column like .177, you would average the values and then divide by 2.
.32+.17+.22+-.11=.6
.6/4=.15 (average)
.15/2=0.075 (correction factor)
So you would add 0.075 to the entire column under .177
Also, remember you have to change the ETC Effective Area Table when you make changes to the ETC Predicted Throttle Angle table.
You will update Effective Area X axis with the top row of Predicted TA.
Then, use the HP Tuners "ETC Effective Area Calculator" to update your Effective Area
https://forum.hptuners.com/showthrea...l=1#post416554
Effective Error.Table.xml
