Results 1 to 5 of 5
Thread: 2019 F150, Turbo, E85, Torque based decel during WOT
    ISSUE: pulling timing during a pull and torque source says (torque based decel)
    2019 F150, On3 turbo, dw95s, e85, 4wd
    When rolling into the throttle everything seems fine, but when leaving from a stop, after the 1/2 shift the torque source says torque based decel, and it pulls all the timing out of the tune and goes lean, eventually by 5th gear it comes back. Anyone ran into this issue? Here is the log and tune file
    log 8 pass.hpl
    2019 5.0l flex fuel turbo tune rev08.hpt
    Advanced Tuner Witt's Avatar
    Aug 2006
    Pittsburgh, PA
    380
    Took a quick glance, your desired load doesn't go above 1.0 possibly because you have map max delta above baro pressure set to 0 under your speed density tab. Could be the PCM trying to limit the torque using enleanment/spark/TB.
    That makes throttle close. But yes on the whipple tune it works
    Oct 2016
    Poland
    1,741
    Quote Originally Posted by konabluekiller View Post
    whipple has different os...i can help you out with turbo tune if you want, not free this but unlocked file. pm me should be interested.
    Advanced Tuner small tuner's Avatar
    Nov 2015
    271
    disable spark adder and flex fuel and start tune on E85 stoich with low spark advance
    Turbocharged COYOTE
    PM for E tune / Remote Tuning
    [email protected]
