Results 1 to 10 of 10
Thread: 80e to 60e OS segment swap??
    Jun 2018
    Illinois
    7
    Angry 80e to 60e OS segment swap??
    OK, so the skinny is I have a 5.3/60e combo in a swapped c10. The computer is a p59 from a buddies 6.0/80e swapped truck (he went TermX).
    I got the harness and ECU swapped and got the thing running and driving, but with only 2 gears. Realized the harness was pinned different for a 80e, changed it back to a 60e pinout and also changed the drop down to a 60e in the tune.
    Now it has only 1 forward gear (its either stuck in 1st or 2nd)
    I was trying to find a OS (1252068) to do a segment swap with, but no luck. Anyone have a 60e tune up with a OS of 1252068 or any other ideas on a solution??? I'm getting burnt out of Troubleshooting and researching, been at it all day.
    Any help would be greatly appreciated!!!
    13,564
    The 1252068 sounds like a upgraded OS, if you click the calibration details page does it say like MAF enhanced tune or Speed density enhanced tune?
    It needs to be a stock file to use the segment swapper.
    Jun 2018
    Illinois
    7
    Lightbulb
    On the OS tab is shows "Speed Density - 2 bar" "OS - 1252068" with an "apply code modification"
    So I'm thinking my only 2 solutions would be to (1) find a complete stock 5.3/60e tune from the repository and start tuning over from scratch. OR (2) is there a best practice for changing the tune-up to a 60e other than what I have done already, which is changing the drop down from 80e to 60e and then copy pasting all the 60e tables from a stock file, or is there a better way out there????
    Jun 2018
    Illinois
    7
    Also wondering if I might brick the ECU if I keep changing the OS. Is there any OS's I should stay away from. The ECU is a P59 from a 2006 Silverado 2500 6.0 DBW
    Jun 2018
    Illinois
    7
    So more info ... If I go to the calibration details page, it shows me a OS of 1213246. However the OS tab shows a OS of 1252068. I'm assuming the first OS listed was the original and the second is the modified one?
    HP Tuners Support
    (foff667)
    Bill@HPTuners's Avatar
    Hailing from Parts Unknown
    28,265
    Quote Originally Posted by tinkaboutit View Post
    Why not just post the .hpt file rather than having us guess?
    Jun 2018
    Illinois
    7
    Good thought, my bad.it worked! started and idled decent, start from here, updated fans and trans.hpt
    Jun 2018
    Illinois
    7
    6..23.hpl and the log of the last drive with the tune-up
    7,619
    That file is not OS 1252068 - it's still the stock 12613246. The OS tab is showing you what it would turn into not what it currently is, and will be blank if a custom OS has been applied.
    Click the toolbar button. Or Edit > Calibration Details. Or CTRL+D.
    Jun 2018
    Illinois
    7
    IC, thank you for educating me. I shall look for a 12613246 60e tune then. Anyone out there have one handy before go downloading 1M files from the repository??
