stall after rev
Recently did a cam swap in a customers car. (220/231 .582/.582 112) (2010 charger R/T 5.7)
This is one our cams we do fairly often.
This one for some reason is giving issues. If you give it a short rev in neutral, when you put it back in gear it will die. If you dont rev it, it wont. After this, it will fire right back up, but then die on its own. I tried starting it several times and it would die every time. If I started the car and reved it in park, it would stay running and would go into gear fine. As long as I dont rev it in neutral it will shift from R to D and back with no issue.
Cam phase limiter is installed, but I am getting a P0014 "echaust (b) camshaft position timing over advanced bank 1" code. Ive never seen this code. I also notice if I rev it in neutral and put into gear, I get a lot of misfires.
Do I have a camshaft position sensor issue, or am I overlooking something in the tune?
2010 charger demon strange issue.hpl
2010 charger demon strange issue.hpt
