I was hoping to get this figured out and not be the 4 millionth guy posting for a little help... but here we are
The current tune has the car starting, idling and purring like a damn kitten at cruising rpms and load. The problem exists when I hit the throttle and begin to build boost. It misses and pops out of the exhaust at the 3200+ RPM range and only baby boost numbers... Mechanically everything is sound... Build specs below, tune and log attached. Wideband will be here in a couple weeks, which is what I need. Just looking for a quick review of the file to call out all the red flags.
5.3 LM7
Summit 8706 Cam (226/230 Dur., 113+4, .600/.575 Lift)
PAC 1218s
Gapped rings, stock everything else.
Truck intake
GM 3BAR MAP
IAT sensor (MAF delete)
7875 turbo
Stock truck manifolds
Decapped truck injectors Flowed/Matched by Huntertuned
Kemso 340 -6AN Feed/Return
TH400
Rattyboost Tune_3BAR OS_Decapp_7875_Working File_vetabletweak_sparktweak_062422_Current.hpt06242022 run 2 tweaked vetable.hpl
