Hey guys, this issue is driving me bananas.. curious if anyone has dealt with something similar or if I'm missing something here 🤔
I have a 102mm TB (holley sniper) on a fast 102. I have already elongated the bolt holes on the tps sensor and I read 0% tps position when the engine is off. When I start the engine it now stays at 1% -/+..
I was thinking the air was pulling the blade or something (thinking weak return spring maybe) I would manually try to hold the blade down by hand against the stop and no changes.
I even tried resetting the tps, starting the car and would move the tps so it finally would read 0% however if I restart the car it comes back at 1% +/-
Turn the motor off its now back to 0% throttle position. And when I press the peddle is a nice and smooth transition from 0 to 100% throttle.
Also have bought a new tps, same issue.
Any ideas?
