Results 1 to 8 of 8
Thread: C7 z06 A8 transmission slipping on 1st gear
    Sep 2016
    391
    The car is a c7 z06, it has a dsx aux pump, a 9 injector meth kit pushing around 30gph, a tsp stage 1 cam with the big fuel lobe, and is running on a mix of 94oct and e98, its crossing the line at 138mph but it seems like i caught some slipping at the top of 1st gear, for next pass i tried adding 15% pressure to the [TCM] 15709 - Base Shift Pressure 1st, TCC on and [TCM] 15673 - Base Shift Pressure 1st, TCC off, but the track got closed due to street car that spread coolant on a lane and a car that caught on fire on the other lane.
    have you guys found this before?
    pass3.hpt
    pass3 10.4 134.hpl
    Advanced Tuner dhoagland's Avatar
    Jun 2015
    Aubrey TX
    890
    I'm not a GEN 5 guy
    One question I have is your engine delivered TQ is 640 but Trans torque read 575...
    The 575 agrees with your virtual torque from my quick glance, possibly issue?
    Shift inertia factor have anything to enhancing shift timing?
    (I know it says for feel, but to me feel is speed manipulation)
    2011 Camaro 2SS Convertible L99 Bone Stock for now
    2003 Dodge 2500 5.9 Cummins QC 4x4. Airaid, 2nd Gen Intake, Grid Heater Delete, D-Tech 62/65/12, Magnaflow. Bully Dog: Propane Injection, Triple Dog W/Outlook Crazy Larry. Edge EZ, BD Flow-Max, 48RE: Sonnax Sure Cure/Transgo combination, Derale turbulator, billet input, Triple Disc, Super servo, 4 ring Accumulator. :beer
    Sep 2016
    391
    Quote Originally Posted by dhoagland View Post
    I'm not a GEN 5 guy
    I tested taking the torque tables up in the dyno but it would close the throttle so i left it back to where it was.
    I did add a couple numbers to the inertia factor as i have read it makes the shifts feel crisper but i didnt feel any difference on the shifting
    Mar 2011
    Ripley, MS
    1,865
    Quote Originally Posted by mJolnir View Post
    Does it feel like it slips, then grabs? If so, it could simply be fluid slosh. You typically want to overfill it by a qt when you have a car that launches hard. I've dropped 3-4 tenths on a few cars with the same issue.
    Jun 2015
    Aubrey TX
    890
    Quote Originally Posted by kevin87turbot View Post
    And it that scenario I imaging the clutch packs don't survive it too many times
    Sep 2016
    391
    its the other way around, it feels like it grabs and then at 5000rpm flares, i thought it was tire slip but as you can see in the datalog speed doesnt go up when that happens.
    Jan 2014
    SoCal
    1,562
    Similar issue but with a Gen 3 I tuned.
    Is the diff gear a 2.41 with a 26 inch tall tire?
    Aug 2014
    Central, LA
    737
    This is when your 1-2 shift starts. Likely 2nd gear is the issue not first.
