Results 1 to 10 of 10
Thread: 2003, 5.3 added BTR stage 4.... oops not enough experiance here.....
    Jun 2019
    29
    Red face 2003, 5.3 added BTR stage 4.... oops not enough experiance here.....
    yes I've used HP tuners for about 5 years.... VAT, Tranny changes, etc... all little minor stuff... this one is a little out of my hands. I've got it so it idles okay... It appears that the trims are working.... but no champain for the performance.
    stock engine,
    stock injectors
    3 angle grind on the heads
    SS plenum
    and then the springs and stuff that go with the BTR stage 4 kit.
    here is a log file and the file I've messed together.
    HELP... if you can :-) It idles, pretty well, sitting it revs up...sounds really nice
    it has no power, wants to die.
    thanks in advance
    Robert
    Advanced Tuner dhoagland's Avatar
    Jun 2015
    Aubrey TX
    890
    Oh my...
    This log is a mess and I'm not sure what data can be trusted.
    You are logging different sensors for the same thing, sometimes one report sometimes both.
    Let pretend the data in the attachment is correct. At idle your are rich as hell on one bank, lean as hell on the other (not just this snap shot, consistently)...
    Then you get on the throttle and both go equal lean.
    Your mas airflow reports 1.6gs of airflow, that can't be right.
    Work on getting a good log so people can help
    Mar 2011
    Ripley, MS
    1,865
    You indicated that the engine is a 5.3L, but the cylinder vol in the tune file is calibrated for a 6.0L engine.
    Do you have the exhaust connected? It's adding a lot of fuel on the passenger bank. That typically indicates a bad exhaust leak (or no exhaust connected), or a misfire or bad oxygen sensor. Occasionally, you'll see the oxygen sensor connectors swapped bank to bank as well. That could very well be the case.
    13,565
    Tune also still has all the transmission related DTC's and abuse mode turned off, that needs to be off.
    And get larger injectors asap, the stockers are way too small.
    2,742
    This is honestly a decently advanced build to tune for.. Not rocket science but... you are definitely jumping right in the fire.
    Have you looked at some of the online tuning training schools? A email tuner might be a good idea to get you going too.. you can watch the progress as you send logs/tunes back and forth.
    Tuner at PCMofnc.com
    Jun 2019
    29
    here is I hope a good log file../
    Again thank you for helping here.
    Robert
    Jun 2015
    Aubrey TX
    890
    Log appears to be better, but I see the same think.
    Look at your o2 on bank 2 sensor 1 it never moves more than a few points idling or on throttle
    Bank 1 sensor 1 moves normal on throttle, but pegs high on idle
    Rear o2's never venture far from .450
    This matches what your fuel trims are doing as I mentioned before
    Did you check out the things Kevin suggested?
    Jun 2019
    29
    Quote Originally Posted by dhoagland View Post
    Rear o2's are connected but are just hanging in the air.no exhaust leaks
    What one thing could I do, change to get idle?
    Jun 2019
    29
    Not idle just to 3000
    Jun 2015
    Aubrey TX
    890
    What do your front o2's read key on engine off?
    I guess you could swap o2 side to side and see if the behavior follows
    Right now it looks like bank (2) o2 is dead
