Im working on a tune for a forged 5.7 edelbrock magnum and when we switched to the party pulley the car seems to hit some kind of a limit once it gets around 14.5lb boost and will force the throttle closed and open to reduce pressure. Car is already running a 3 bar MAP, is there anything in the tune that can be done to prevent this or should I try something like a Map clamp? Already upgraded to a hellcat TB in case the stock TB was the issue but no luck.
