ls swapp second read with bigger injectors.hpt
can someone shed some light on this?
rebuilt lq4 stock bottom end new rings and bearings stage 2 cam 228-230 @.050 .585 lift 112 lsa
ported 317's (going to boost it soon) stock tune ran ok with the factory truck intake then i put a fitech 102 mm 70076 kit minus the computer as i am running a gm 0411 with hpt
it won't idle. when i give it a little throttle it will shoot up to 1,180 ish then go down to 380/400 then stumble and die.
it currently has a 1 bar map and a 1 bap maf, i purchased a gm 3 bar and tried it with no maf it will run but not run right.
i bumped up the injectors in the tune to 55. as that's what's in the intake currently.
looking for some InSite, dyno guy told me to get it running basically before he will dyno it for numbers.
i attached the tune it has and will upload a data scan also shitty pooping b.hpl
read a thread that fitech had a issue with the iac but it was a different kit or was a user error.
any help would be great .
