Results 1 to 5 of 5
Thread: L29, 0411 swap, problem with running rich on start up
    Mar 2022
    8
    Hi , i have a L29 454, 0411 swap, mercruiser magnum cam ( tow cam ) 9.8:1 compression, wondering if i can get some advice , every time it starts , hot or cold, it runs rich for 5-10 seconds until it clears, the injectors & pressure regulator are not leaking. If i lower the numbers on the start VE & VE tables at idle, a fair bit , it starts good , but stalls when its put in to gear. not sure how to reduce cranking fuel delivery. Thanks
    13,559
    Which injectors is this vehicle running?
    Mar 2022
    8
    Same as the standard 19lb ones
    13,559
    Is all the injector data correct then?
    I ask because that tune says 23lb/hr and not 19hr/lb. I don't have a stock tune with 19lb/hr data to look at, at the moment.
    If other parts of the data are wrong, that can cause weird fueling problems.
    Mar 2022
    8
    Ok thanks, I'll check what i have.
