Originally Posted by GSLSE20B 91-e85 flex Hi, I did see that flex fuel was disabled in the previous file, just didnt know if any other settings needed to be changed as well, thanks.
Do you want flex or a max effort e85 only ?
Originally Posted by GSLSE20B Do you want flex or a max effort e85 only ? going to run it low on pump the put in some vp e85 and then back to pump without changing the tune
Posted will work , pump e85 is fine . I would save the VP for an e85 only map where you can smash in all the timing from low rpm
