Results 1 to 5 of 5
Thread: '71 RoadRunner 5.7 Hemi Swapped
    Aug 2020
    37
    I have a "71 Roadrunner with a 2005 5.7 Hemi/ manual trans swapped in. over all the car runs great and has a good idle, good acceleration and overall seems to be in order with the exception of coming to a stop and the vehicle dies, and the throttle doesn't fall very quickly when WOT shifting .
    I've tuned on this car for a few weeks and just can't seem to get the problem isolated. I don not use a VSS, because it's all mechanically driven off the transmission (A855)
    NGC4 PCM
    Any help would be appreciated!
    Advanced Tuner rays04gtx's Avatar
    Oct 2021
    Allentown PA
    363
    Stock Cam ? I have a 66 dart with a 6.1/A833 in it, PCM set up out of an 05 Durango. What worked for my dart is
    Engine>General>Displacement , it's set to 0
    Engine>Airflow>General>Sensed MAP is disabled.
    Also and I'm not sure this is your issue, or contributing to it.
    Engine>Torque Model>Loss>friction your table is stock. Might want to take from 4400RPM up ,all MAP values and reduce them by 10% , same with everything under 1200 Rpms ,
    I'm running a big custom cam in my 6.1 but it wouldn't idle for crap till I played around with the Friction table.
    Throttle after WOT , not sure where to direct you on that .
    Also all of my idle tables are
    A855 , tried buying one from Passon , but they were never in stock....did the T56 swap instead.
    62 Biscayne 425/409 SS/D stock class car 10.60s
    66 Dart 426CIG3 8.60@171 2750lbs Naturally asperated
    04 Ram All Alum , 468Ci G3 10.50s @4800 lbs Naturally asperated
    04 Rumble Bee, built 6.1 ,4000lbs 10.48 @ 129s MPH. Naturally asperated
    05 Rumble Stock 5.7, 3.92s TUNE ONLY 13.94@98mph
    Mar 2022
    11
    These old school vehicles with hemis are absolutely cool. When I said goodbye to my 72 Duster, I was looking for a project and a '69 Dart with a hemi came to mind.
    Aug 2020
    37
    Thank you for all the help!
    Got it where it doesn't stall out and die when coming to a stop!
    Zero'd out all the idle tables and just set it to static idle at 872rpm.
    Still working on the throttle hang when doing hard wot pulls and shifting fast, it takes about 2-3 secs for the rpm to fall.
    Current tune:
    Oct 2021
    Allentown PA
    363
    What I wanted to say about idles , before I had a senior moment and forgot I didn't type it in..
    I make all my idle tables close to my desired Idle.
    Not sure about the throttle hang
