Need more information on this. Is this a cam only car? What mods have you done? Do you have a log you can attach? You could try to lower the Base Running Airflow by 10% and see if that helps at all..just make sure that your Park and Neutral are the same.
see if this helps any. I made some changes to your BRAF table and cut the Idle Spark Adder down some. Have you been able to get a log that you can upload?
