Results 1 to 4 of 4
Thread: Car running lean while idling/cruising
    Mar 2022
    4
    Exclamation Car running lean while idling/cruising
    Unfortunetly i went throught the chevy transmission problem with the torque converter. I had this torque converter on hand when I wanted to go procharged so i had the guy install it thinking it would not cause any issues just being a higher stall. It has been idling lean ever since i did that.
    I am going to post two file with log1 being the log after the torque converter install and MafPartThrottleFinal being before the converter install.. any help is appreciated.
    I also changed my 02 sensors already and have new spark plugs too.
    Mar 2022
    4
    I can also give more information on my car if needed too
    17 camaro ss
    MSD Intake
    2" headers
    NGK iridium spark plugs
    13,565
    The file that says "Log1" is not running lean, it's running rich. Negative fuel trims means it's pulling a fuel, and that log is pulling a lot of fuel just to try and make it run okay.
    The second data log looks really normal to me as far as fuel trims go, nothing really wrong there.
    You just have 4 o2 sensor codes for the rear sensors and possible they are permanent codes if they were turned off after you already removed the parts.
    Mar 2022
    4
    So you recommend me to remove?
    17 camaro ss
    MSD Intake
    2" headers
