Results 1 to 3 of 3
Thread: 2013 CTS-V Cooling Fan Parameters
    Jul 2022
    I am new to HPtuners but have used other tools like Forscan in the past. I am not happy with the temp that my 2013 V cooling fans kick on at. I would like to install a cooler thermostat and have the cooling fans kick on sooner at a lower temp. Is there a guide available that shows which parameters would need to be changed to achieve this?
    Thanks in advance
    You are limited ~195 degrees, unless you want fans on at all times.
    You can try these settings, but even with 160 Tstat, aftermarket radiator and fans, I have cooling issues out here, when temps are 108+.
    You will most likely see ~172 degrees in winter time with 160 when on the highway, but that's about it.
    If anyone else got better settings, please do share.
    Advanced Tuner Shrek's Avatar
    Nov 2011
    753
    Your 2013 CTS-V uses an E67 ECM, with GM OS 12653669.
    HP Tuners offers an upgrade for this GM OS - to HPT OS 1250240 - which would provide you with the ability to control the cooling fans beginning at 160F (OEM is 192F).
    This OS upgrade can sometimes be a little difficult for a novice tuner to use. It provides an actual VE table - but it is not populated by default (zeros only) - the end user has to sort this out on their own.
