Page 1 of 2 12 LastLast
Results 1 to 20 of 25
Thread: Trailblazer E40 Question
    Jul 2022
    13
    Hello newbie to the group!
    Have this 2004 Colorado 4x4 build with a 5.3 gen3 using E40 Trailblazer and t42 Tcm. Truck is running and to finalize this build I'm looking into running electric fans. From a group on Facebook a popular fan of choice is out of 08 or so Charger as the dimensions are perfect for the radiator. Problem is the blazer has clutch fan with a Hall sensor. I made this harness custom and do not have any of that. Was planning to using relays and C1- Pin 36 as the control. In the schematic that wire goes into a relay then powers the motor. Just unsure about how that wire energizes to turn the fan on, what the settings should be set to, if the Hall sensor portion is needed OR worst case scenario special fan control module needed. Appreciate any input!
    7,600
    Copy the low speed side of a '05-'06 GTO. Those used regular relay fans.
    The control pin(s) in the ECM provide a ground when activated, so you'd have constant power to one side of the relay coil and the ECM completing the ckt to ground when fan is requested.
    Edited GTO diagram to get you the basics:
    p.s. In HPTuners-world, E40 is classified as a Gen 4.
    7,600
    Wait, what is this Charger fan? What type motor, brushed and relay controlled, or brushless/variable speed PWM controlled?
    Jul 2022
    13
    I have what are the heavy duty dual fans from 08-09 charger. Are controlled by Pcm, variable speeds, and relays are used. Unsure if brushed or brushless were pulled from junkyard. So with my pin out situation C1-36 is cooling fan clutch control C1-23 is Speed signal. C3-33 is Low Reference an 35 is 5 volt Ref. This is a different setup from my 1990 c1500 2005 6.0 swap Blue and Green connecter Pcm.
    7,600
    If they are variable speed fans there will have to be some kind of controller, either between ECM and fans or built into the fan motors. The ECM can't do variable speed to a brushed fan without some other module inbetween to handle the high current switching. If they're brushless the controller will be built in and it'll use 3 wires, constant B+, constant ground, and a PWM signal.
    Jul 2022
    13
    After looking at a few diagrams there are 3 relays used, one high speed signal and on low kind of like the green and blue connecter on a gen3 pcm besides the 12 key hot, this look constant B+.
    https://www.challengertalk.com/cdn-c...-jpeg.1040072/
    Site shows Challenger however fans are the same on Charger comparing part numbers on rockauto.
    7,600
    For a 2-speed brushed motor fan you need two relays and two ECM output pins. Low speed feeds the fan terminal with the resistor, high speed feeds the one without.
    Jul 2022
    13
    Alright, so with my current ECM setup it can not be done is what i'm trying to get at.
    7,600
    E40 has two output pins available. GTO uses a 3-relay setup with two output pins.
    You would use only two relays - C1 36 to ground the relay that powers the resistor/low speed pin at the fan, and C1 56 to the relay that goes to the non-resistor/high speed fan pin.
    Jul 2022
    13
    Alright understood, Wiring it up i can do, just would the trailblazer programming work the same as the GTO
    7,600
    If you change the settings from the Trailblazer's PWM EV/1 fan*/2Hz to Discrete/2 fans/128Hz, and the relevant stuff in State vs Desired & Output vs State...
    * 'Number of fans: 0/1/2/3' actually means the number of fan output pins being used, not the number of motors with fan blades on them. A single two-speed fan needs two output pins, so Number of fans: 2.
    7,600
    Just so you and anyone else that sees this later is clear, the Charger fan-thing is not variable speed, it's multiple speed, which is completely different animals.
    Jul 2022
    13
    Sounds good, Thank you for your help and patience I really appreciate it. I didn't have this much confusion with my first LS based swap lol. So i will pin into c1-36 c1-56, use the Similar wiring schematic as the GTO with two relays to be fully comprehend.
    7,600
    I found an Aveo that had a 2-speed fan w/resistor, so I built you a new diagram...
    Jul 2022
    13
    That'll work excellently, with the resistor that'll be needed for both fans correct? I see it is an available part for purchase locally.
    7,600
    https://www.rockauto.com/en/catalog/...+assembly,2181
    What I gather from that page is that:
    Std cooling = dual fans, two 2-pin connectors
    HD cooling = big single fan, one 3-pin connector, resistor integrated into backside of connector
    If you have the big single, use the diagram I spent about 40 minutes making.
    If you have the dual fans, shit, just use a 3-relay system copied direct wire-for-wire from the unaltered GTO diagram. That way you can have low speed with the fans connected in series and then high speed with both connected in parallel.
    Jul 2022
    13
    Awesome yeah I have the dual fans so i should be set to try it out.
    Jul 2022
    13
    Everything works as it should after the long pause. Drove the truck tonight and stayed right in the middle around 203-208 degrees. Thank You for your time and patience with me I really appreciate it.
    Aug 2019
    Colombia
    76
    I'm having a similar situation with a e40. I want to do a ECM single wire to activate 2 fans with relays around 190f. Can you please share your tune to see how should I configure it on mine?
    7,600
    With only a single wire from the ECM, you'll only be able to get all fans on at 100% or all fans off, no matter how many relays or fans you have. Is that what you're wanting?
