In the torque management tab, general, there are 2 sections for max torque.
1st section, "Maximum Torque," is just a single button "RPM vs Gear." Makes sense to me.
2nd section, "Torque limit vs RPM,", with buttons for each gear, but still adjusted by rpm within each table. Also makes sense to me.
HP tuners says this:
Max Engine Torque vs. RPM vs. Gear: Maximum allowed engine torque vs. RPM and current gear for transmission protection. Electronic Throttle Fitted Vehicles only.
Max Torque vs. Gear: Maximum allowed engine torque vs. current gear. (I don't have this table)
Max Torque vs. RPM: Maximum allowed engine torque vs. RPM, whilst TCC locked.
Basically I'm going to attempt to use these tables to pull power in 1st and 2nd gear for traction/consistency. But I don't know which one I need to edit, and if they'll fight each other.
EDIT: I have a manual so I'm guessing the vs rpm tables just won't apply to me. But then does the rpm vs gear table not apply to me either?
