Results 1 to 4 of 4
Thread: how many cell hits in scanner
    Jul 2021
    42
    I'm new to tuning...what is a good setting for cell hits in scanner when data logging. I currently have mine seat a 5. Is that too high?
    Advanced Tuner Cringer's Avatar
    Aug 2021
    Somewhere smoothing your VVE table
    512
    Quote Originally Posted by Dwg86 View Post
    Well what are you logging?
    For knock retard, 5 is too high. Set it to zero.
    For fuel trim, 5 is too low. Set it to 50 or 100.
    Fortunately it is easy to change that anytime to see if the data drastically changes, so experiment to see what works best.
    7,641
    Quote Originally Posted by Cringer View Post
    To expand on what that means, you can apply or change filters and hit counts and even entire charts/graphs after-the-fact, after the log is over. A .hpl logfile is ONLY the channel data. The charts/graphs/whatever else is applied to what's recorded from the channels.
    And, if you log on a laptop and then review/edit on a different machine, your logging laptop doesn't need to have any charts/graphs running at all, which can help with processor load. Have all the fancy processing stuff only in the scanner on the editing machine.
    Advanced Tuner f.creek-ranch's Avatar
    May 2018
    Germany
    586
    There are many ways.
    I set it to 0 and drive over 1 hour for fuel trims. So you get enough data.
