Hello,
I am trying to do a accel pedal relearn on my project car. I have swapped in a GM performance LS3 Gen4 crate engine with e67 ECM (also from GM performance). As part of the project I installed a OBP pedal box that utilized a linear potentiometer for drive by wire. It has a 6-wire setup just like the standard GM pedal. However, I need to be able to complete a accel pedal re-learn to calibrate 0-100% throttle position. I have looked under "special functions" as some videos have suggested but i do not find pedal relearn as an option. Only Crank Relearn.
Any help would be appreciated.
E36 M3 w/ LS3 swap
