EDIT: I think I figured it out after watching a YouTube video.... I was logging MAP in kpa in the KR scanner graph instead of cylinder airmass. Will try again tomorrow to see if this if this is the fix.
Edit 2.... 8/3/2022: I was able to fix the graph but still logging 0's.
See attached log and tune.
I read the main things you need in the channel list to log KR are cylinder airmass and knock retard. I have both of those in the scanner. My spark table is moderately aggressive for only running 87 octane (no ethanol E0) but still, I'm seeing zero's across the entire rev range.
Am I missing something easy here?cruise control test.hplMAF Tuning 1.0.hptno KR.JPG
