Results 1 to 2 of 2
Thread: Torqhead Timing Problems
    Just completed a 24X TORQHEAD conversion on my 1997 Firebird, it came with a custom tune to get me started with my new engine. I cannot seem to break in the engine without the headers glowing red! HP Tuner says the timing is at 41 degrees at light throttle and 2000 RPM ? Seems a bit high.. I tried added more fuel pressure but no improvement. Any suggestions on how to get the timing more in line with low speed light throttle for new engine break-in?
    Make and Model: Pontiac Formula
    Engine Size (L):6.3L
    Transmission Type and Model: Tremec six speed
    Transmission Spec (Stock or Built): Stock
    Rear End Gear Ratio: 4:10
    Current Tire Size: 275/40/R17
    Desired Shift Firmness (Slight, Moderate, or Very Firm):N/A
    Torque Converter (Make/Stall): N/A
    Injectors (Make/Model/Size): Accel ? 150836 36 lbs I will be running the fuel pressure at 50psi they will act like 42lbs
    Fuel Octane: 93
    Thermostat (Stock/160/180/195): 160
    MAF (Stock LT1/3.5” LT1/Other): Granatelli 350331
    Ported MAF (Yes/No): No
    De-screened MAF (Yes/No): No
    MAP Sensor (stock, 2 bar, 3 bar): Stock
    ? Throttle Body Size:? 58MM
    Cold Air Intake (Yes/No): Ram Air
    Intake Manifold (Stock LT1/Ported LT1): Ported Lt4
    Exhaust Manifold (Stock/Other ?): Kooks Long Tube 1-3/4 Headers?
    Catalytic Converters: Kooks High Flow
    Cat Back Exhaust: Kooks 3 inch True Dual Exhaust
    Nitrous (Yes/No): No
    Camshaft (Make/Model/Specs): Comp Cams 280 XFI cam duration @ 50 is 230/236 Lift is 570/571 LSA 113
    Cylinder Head Specs: AFR Heads 1101 ? 210 competition Heads flow Rate @.550 Lift intake/310 Exhaust/229. @.600 lift intake/318 Exhaust/236
    Rocker Ratio: 1.65
    Compression Ratio: 11:32:1
    Aug 2009
    Calibrating
    3,373
    Didn’t get a chance to look but t the start up tune from any of these conversion places is not really a good start (other then the fact injector bank select is correct for the lt1 engine)
    I do a lot of these, if I can help let me know..
    But I would check system for a vac leak, as the system is most likely pulling all the timing out to lower idle speed hence the glowing headers from a reduction in spark. I’m sure IAC is 0 as well
    15 C7 A8 H/C 2.3 Blower/PI
    14 Gen 5 Viper
