Results 1 to 20 of 35
Thread: 4L60E Shifting Way too Early
    Jun 2022
    28
    So I finally got the Gen 3 LM7 w/ 4L60E in my '66 C10 tuned and running quite nicely. The problem now is that it's shifting way too early - I have the speedometer / VSS properly calibrated to my gear ratio / tire size, but when driving, it feels like it's bogging down HARD especially at lower gears, and not accelerating properly, so I plugged it into the VCM Scanner so I can see what's going on.
    From what I can tell, it is shifting gears, but not at the right speeds. I can physically feel the 1-2 shift happening at close to 5 MPH. And earlier today I was in 4th gear going 25 MPH.
    Any idea on where I should look first to fix this?
    7,759
    Quote Originally Posted by spectre1995 View Post
    Advanced Tuner dhoagland's Avatar
    Jun 2015
    Aubrey TX
    890
    Request permission to use photo in the future
    Jun 2022
    28
    Just double checking - presumably you're looking for an upload of the tune file I'm using?
    1,528
    Tune and log usually.
    Jun 2022
    28
    I'll have to read up on how to compile a log - I've just been watching the live readouts
    Jun 2022
    28
    For starters, here's the tune file. I don't currently have a log but I'll get one later today.
    Jun 2015
    Aubrey TX
    890
    From your scanner when you click the stop scanning Icon...
    You will be looking at a screen like the picture.
    Then you can click log file, the save log file as from the drop down. Or Click the "Save as" File icon.
    Then save to a folder of your choice. I believe the default is something like this C:\Users\daniel.hoagland\Documents\HP Tuners\VCM Scanner\Logs\Jesse
    After Saved you can follow blindsquirrel's upload guide
    Jun 2022
    28
    And here's the log from a quick lap around the block
    7,759
    Well that's definitely weird all right. Also the 1st-3rd-1st every time you come to a stop.
    Was the file's rear gear originally 3.73, or did you change that and then scale the shift points? If you did change it, have you tested with everything (even speedo) reverted to stock, just to see if it affects this specific problem?
    Jun 2022
    28
    Yeah I think it was originally 3.43, I had tested it with that and had a similar issue. I changed it to 3.73 to match what's in the truck's rear end and it doesn't seem to have changed much, at least not enough for me to notice anything significant. Before changing it, the speedo was wildly inaccurate - now it's "close" but not 100% perfect.
    7,759
    I wouldn't worry about the accuracy of the speedo until it's shifting at the correct MPH (indicated, not actual). If it shifts when it should with everything copied from a stock file you can put your changes back in one at a time.
    I see the PCM's VIN is a 2WD, is it still? You haven't changed anything in the trans like output shaft? Did the engine/trans/PCM all come from the same donor?
    Jun 2022
    28
    Yea it's still a 2WD. The engine and trans came from the same vehicle (2004 / 2005 ish Chevy Tahoe 5.3L non flex w/ 4L60E) but the PCM came from another vehicle (2005 Chevy Express 6.0L with 4L60E).
    I didn't change much from the stock file other than removing some evaporative / emissions related things from the DTC list. I think I made some other small changes as well, but nothing to the transmission with the exception of the gear ratio / tire size calculator. Also when I ran the stock file with no modifications to it about a month or so ago, I had the same shifting issues
    7,759
    Are you sure the '05 Express PCM service number is compatible with the '04 Silverado file you put on it?
    Jun 2022
    28
    As far as I've been told, they're compatible but I'm very new to all of this so I have no way of really knowing until I try it out. Have you found anything that might indicate this might be the issue? Or possibly anything in the tune file that could be a potential factor?
    7,759
    What was the VIN of the '05 Express? When you go look up a PCM for that VIN, does that number also interchange with the new file? From what I'm seeing, without a VIN to go on, they use different service numbers ('04 Silverado 1500 LM7 and '05 Express 2500 LQ4). If they were functionally identical and could run the same calibrations the parts listings would normally get consolidated down into a single (or the minimum number) of part numbers.
    7,759
    Jun 2022
    28
    From the tune that was on the PCM before I flashed it;
    Creation Date: 6/28/2022 12:39:45 AM
    VIN: 1GBJG31U151196734
    2005 Chevrolet Express 3500, 6.0 L, V8
    Hardware: P59, GM Gen3 V8, 4.3L V6
    Serial: 0MA05QGV5025
    OS: 12592618
    From the tune I flashed on it (from the repository);
    Creation Date: 6/22/2016 7:48:24 PM
    VIN: 2GCEC19T141186089
    2004 Chevrolet Silverado 1500, 5.3 L, V8
    Serial: 1LA08U7Y3265
    OS: 12587603
    7,759
    04 Silverado 2GCEC19T141186089: 12581565, 89017733
    05 Express 1GBJG31U151196734: 89017749, 12589462, 12602801
    Jun 2022
    28
    Got it - so it's a PCM issue after all?
    Should I just source one from a junkyard or order it new?
