Hello,
2013 ZL1 LSA modified engine with over 1,000hp.
Livernois dual fuel pumps.
I use the Beta software.
My fuel pressure drop with higher rpm's, I am sure it is due to the fuel pumps not being able to keep up with engine demands. Still a lot of room for the injector duty cycle.
I have searched the forums for the info I need but just ended up confusing myself. I am including the log from the dyno run. I have just installed a 3rd fuel pump with a 5psi hobbs switch. So I do not know if the 3rd pump will correct this issue yet. I read in other posts that with a boost pump installed that the FPCM = Mode Conditions = [ECM] 17022 - High Flow Upper, [ECM] 17023 - High Flow Lower, [ECM] 17020 - Low Flow Upper and [ECM] 17021 - Low Flow Lower need to be adjusted.
Some of what I read said to adjust them higher and some say lower...
Any advice and help would be greatly appreciated. Please ask if you require more information.
Thank You, Victor
