No speed reading on a LT4/Tremec TKX trans swap in a 69' Camaro. The TKX trans has an older style 5th gen Camaro output speed sensor with the matching connector on the aftermarket harness. Looking at my 2017 Camaro m6, it has a different style 3 wire hall effect sensor which matches up with the C7 and 6th gen Camaro wiring diagrams I have. Anyone know if adjustments can be made to the speedo hardware settings to get the e92 pcm to read a two wire sensor? It looks like GM uses the older sensor with the Connect and Cruise LT1 kits. Maybe one you guys has a stock file from one of those kits?
