Results 1 to 7 of 7
Thread: 2011 l99 ss camaro 6.2 need tune
    May 2022
    34
    i have a basically stock 6.2 automatic car, it has a cold air intake, cats and straight pipe duals cat back. dose someone have a tuned tune you can send me to copy on my car, as of now even with trac off and stabilitrac off it will not burn out from dead stop, and seems laggy , its not acting like a 400hp car, i bought it like this and dealer knew nothing about it, any help appreciated. thanks
    Tuner JnJSpdShop's Avatar
    Aug 2005
    Western New York
    195
    What cold air intake?
    Western New York's Performance Headquarters
    716.830.0506
    May 2022
    34
    I believe it?s a k and n , I?m wanting a tune sent so I can try to do myself, to learn more about hp tuners
    Advanced Tuner PGA2B's Avatar
    Nov 2004
    St. Louis, MO
    474
    Since the tune in the car is unknown I would go the the repository and look for a stock tune and compare it to what is in the car.
    Have you read your current tune?
    That way you can see what has been changed.
    2013 OBM A6 CTS-V Coupe
    Mods: Headers back Billy Boat Exhaust, GripTec 2.65, 8.6 PowerBond Lower, LSX Innovations Solid Isolator, ID850's, NGK TR7IX's, Accel 9070CK Wires, Spectre CAI, SRI Ported Throttle Body, SRI Catch Can, NGK AFRM, 160* T-Stat, 0fx2gv Brick, Hard Line Delete W/3/4" Lines, FB 101 FMIC, Pierberg CWA50, Stoptech Drilled/Slotted Rotors, EBC Redstuff, Cut Stock Springs, Flat Bottom Steering Wheel
    2006 Black Raven STS-V (Traded In)
    Fully Modded: 459RWHP@5888rpm/451lbft@4696rpm
    Advanced Tuner dhoagland's Avatar
    Jun 2015
    Aubrey TX
    890
    Post up your Tune and a Log
    I'll let ya look at mine for reference, but with my upgraded injectors it will do you no good.
    This is my 2011 L99
    -Roto-fab intake
    -AFM Off
    -ZL 1 fuel pump
    -E85 Sensor Added
    -12609749 injectors installed
    -Transmission Settings Mirror 2010 CTSV
    (Cam, AFM delete, and High flow cats sitting on the floor)
    2011 Camaro 2SS Convertible L99 Bone Stock for now
    2003 Dodge 2500 5.9 Cummins QC 4x4. Airaid, 2nd Gen Intake, Grid Heater Delete, D-Tech 62/65/12, Magnaflow. Bully Dog: Propane Injection, Triple Dog W/Outlook Crazy Larry. Edge EZ, BD Flow-Max, 48RE: Sonnax Sure Cure/Transgo combination, Derale turbulator, billet input, Triple Disc, Super servo, 4 ring Accumulator. :beer
    May 2022
    34
    currant tune on the car
    Jun 2015
    Aubrey TX
    890
    Read your TCM too
    A log will be necessary for people to see what is going on
