Originally Posted by
hjtrbo
Will need an adapt reset after playing with virtual torque.
Shouldn't be slipping at all.
A log with low, mid and WOT torque shifts would be ideal. At a minimum have the following PID's
Trans slip, TCC slip, TCC pressure, PCS-1 pressure, time of latest shift, commanded gear, trans engine torque.
Right click trans slip / tcc slip / pcs-1 pressure and trans engine torque and set polling to 20Hz.
Have you got a stock tune to compare to.
Noticed a couple of things, your shift pressures for a couple of gears could come up a bit, your shift times could come down and get rid of the discrete shift torque for 2-3.
