Hello,
So I may better understand and maybe have some guidelines to base a tune-off of how does OBD readings get impacted with a plug-and-play? For instance, with the Racechip snugged between the IC and Engine intercepting signals there, would I see the impact on the ECU read, or not bc the OBD is recording the ECU and the changes are happening post ECU output?
