Results 1 to 4 of 4
Thread: data not populating in scanner
    Dec 2020
    38
    I had this problem before and tried the same thing this time to fix it but still will not work.
    Last time i was logging the MAF which cause my AFR error to not populated numbers in the cells.
    Anyone care to look at this? log file and see if you have AFR error?testing afr.hpl
    13,565
    Try repolling for supported parameters after you connect to the vehicle and before you start scanning again.
    Jul 2022
    14
    How exactly do you do that?
    7,627
    Vehicle > Connect
    then
    Vehicle > Repoll For Supported Parameters
